Return to SiSEC 2015
UND 2015
Underdetermined-speech and music mixtures
We propose to repeat the underdetermined-speech and music mixtures task in SiSEC2013.
Test data
We have three datasets:
Download test.zip (22 MB) (test data of SiSEC2008.)
Download test2.zip (16 MB) (test data of SiSEC2010.)
Download test3.zip (8.6MB)(test data of SiSEC2011. This is the 3-ch mixtures of 4 speech sources.)
test.zip
test.zip contains three types of stereo mixtures and we use the following two:
  • instantaneous mixtures (static sources scaled by positive gains)
  • live recordings (static sources played through loudspeakers in a meeting room, recorded one at a time by a pair of omnidirectional microphones and subsequently added together)
    • CAUTION: For SiSEC2015, we will NOT evaluate “synthetic convolutive mixtures” (static sources filtered by synthetic room impulse responses simulating a pair of omnidirectional microphones via the Roomsim toolbox).
The room dimensions are the same for synthetic convolutive mixtures and live recordings (4.45 x 3.55 x 2.5 m). The reverberation time is set to either 130 ms or 250 ms and the distance between the two microphones to either 5 cm or 1 m, resulting in 9 mixing conditions overall.
For each mixing condition, 6 mixture signals have been generated from different sets of source signals placed at different spatial positions:
  • 4 male speech sources
  • 4 female speech sources
  • 3 male speech sources
  • 3 female speech sources
  • 3 non-percussive music sources
  • 3 music sources including drums
The source directions of arrival vary between -60 degrees and +60 degrees with a minimal spacing of 15 degrees and the distances between the sources and the center of the microphone pair vary between 80 cm and 1.20 m.
The data consist of stereo WAV audio files, that can be imported in Matlab using the wavread command. These files are named test_____mix.wav, where is a shortcut for the set of source signals, for a shortcut for the mixture type, the reverberation time and the microphone spacing.
Licensing issue: These files are made available under the terms of the Creative Commons Attribution-NonCommercial-ShareAlike 2.0 license. The authors are Glen Phillips, Mark Engelberg, Psycho Voyager, Nine Inch Nails and Ali Farka Touré for music source signals and Shoko Araki and Emmanuel Vincent for mixture signals.
test2.zip
test2.zip contains two types of stereo mixtures:
  • instantaneous mixtures (static sources scaled by positive and negative gains)
  • simulated recordings (static sources filtered by impulse responses recorded in a real room situation with loudspeakers and omnidirectional microphones)
The room dimension for simulated recordings was 4.45 x 3.55 x 2.5 m, and the distances between the sources and the center of the microphone pair was 1.20 m. The reverberation time for simulated recordings was set to either 130 ms or 380 ms and the distance between the two microphones to either 4 cm or 20 cm. Therefore, 5 mixing conditions are considered, together with instantaneous mixtures.
The data consist of stereo WAV audio files, that can be imported in Matlab using the wavread command. These files are named test2_____mix.wav, where is a shortcut for the set of source signals, for a shortcut for the mixture type, the reverberation time and the microphone spacing.
Licensing Issue: These files are made available under the terms of the Creative Commons Attribution-NonCommercial-ShareAlike 2.0 license. The authors are Shannon Hurley, Nine Inch Nails, AlexQ (Alexander Lozupone), Mokamed, Carl Leth and Jim’s Big Ego for music source signals and Hiroshi Sawada for mixture signals.
test3.zip
test3.zip contains two types of 3-ch mixtures:
The room dimension for simulated recordings was 4.45 x 3.55 x 2.5 m, and the distances between the sources and the center of the microphone array (linear array) was 1.0 m. The reverberation time for simulated recordings was set to either 130 ms or 380 ms and the distance between the two microphones to either 5 cm or 50 cm. Therefore, 5 mixing conditions are considered, together with instantaneous mixtures.
For each mixing condition, 2 mixture signals have been generated from different sets of source signals placed at different spatial positions:
The data consist of stereo WAV audio files, that can be imported in Matlab using the wavread command. These files are named test3_____mix.wav, where is a shortcut for the set of source signals, for a shortcut for the mixture type, the reverberation time and the microphone spacing.
Licensing Issue: These files are made available under the terms of the Creative Commons Attribution-NonCommercial-ShareAlike 2.0 license. The author is Shoko Araki for mixture signals.
Development data
Download dev1.zip (91 MB)
Download dev2.zip (47 MB)
Download dev3.zip (47 MB)
(The former development data of SiSEC2008, SiSEC2010 and SiSEC2011.)
The data consist of Matlab MAT-files and WAV audio files, that can be imported in Matlab using the commands load and wavread respectively. These files are named as follows:
  • dev1____src_.wav: mono source signal
  • dev1__inst_matrix.mat: mixing matrix for instantaneous mixtures
  • dev1_____setup.txt: positions of the sources for convolutive mixtures
  • dev1_____filt.mat: mixing filter system for convolutive mixtures
  • dev1_____sim_.wav: stereo contribution of a source signal to the two mixture channels
  • dev1_____mix.wav: stereo mixture signal
where is a shortcut for the set of source signals, for a shortcut for the mixture type, the reverberation time, the microphone spacing and the source index.
All mixture signals and source image signals have 10s duration. Music source signals have 11s duration to avoid border effects within convolutive mixtures. The last 10s are then selected once the mixing system has been applied.
Note about dev1 and dev2
The development data dev1 and dev2 have the same setup as that of test1.
The development set corresponding to test2 is not provided.
Note about dev3
The development data dev3 consists only of WAV audio files,
  • dev3____src_.wav: mono source signal
  • dev3_____sim_.wav: stereo contribution of a source signal to the two mixture channels
  • dev3_____mix.wav: stereo mixture signal
Licensing issue: These files are made available under the terms of the Creative Commons Attribution-NonCommercial-ShareAlike 2.0 license. The authors are Another Dreamer and Alex Q for music source signals and Hiroshi Sawada, Shoko Araki and Emmanuel Vincent for mixture signals.
Tasks
The source separation problem has been split into three tasks:
    1. source counting (estimate the number of sources)
    2. source signal estimation (estimate the mono source signals)
    3. source spatial image estimation (estimate the stereo contribution of each source to the two mixture channels)
Submissions
Each participant is asked to submit the results of his/her algorithm for tasks 2 and/or 3
The results for task 1 may also be submitted.
In addition, each participant is asked to provide basic information about his/her algorithm (e.g. a bibliographical reference) and to declare its average running time, expressed in seconds per test excerpt and per GHz of CPU.
How to submit
Each participant should make his results available online in the form of a tarball called _.zip.
The included files must be named as follows:
  • _____src_.wav: Estimated source for task 2. Mono WAV file sampled at 16 kHz.
  • _____sim_.wav: Estimated spatial image of source for task 3. Stereo (3ch for test3/dev3) WAV file sampled at 16 kHz.
  • task1.txt: Estimated source numbers for task 1. The file’s 1st column is the mixture label (dev1_____mix) and 2nd column is the estimated number of sources.
where is one of the test/test2/test3/dev2/dev3, is a shortcut for the set of source signals, for a shortcut for the mixture type, the reverberation time and the microphone spacing.
Each participant should then send an email to “d-kitamura (at) nii.ac.jp” providing:
  • contact information (name, affiliation)
  • basic information about his/her algorithm, including its average running time (in seconds per test excerpt and per GHz of CPU) and a bibliographical reference if possible
  • the URL of the tarball(s)
Note that the submitted audio files will be made available on a website under the terms of the Creative Commons Attribution-NonCommercial-ShareAlike 2.0 license.
Reference software
Please refer the previous SiSEC2008 page.
Evaluation criteria
We propose to use the same evaluation criteria as in SiSEC 2010, except that the order of the estimated sources must be recovered.
The estimated speech signals in tasks 3 and 4 will be evaluated via the energy ratio criteria defined in the BSS_EVAL toolbox allowing arbitrary filtering between the estimated source and the true source and via the perceptually-motivated criteria in the PEASS toolkit.
Performance will be compared to that of ideal binary masking as a benchmark (i.e. binary masks providing maximum SDR), computed over a STFT or a cochleagram.
The above performance criteria and benchmarks are respectively implemented in
Task proposed by Audio Committee
